trevorsync
I have been able to generate an algorithm to randomise a bit position where an error is likely to occur.Which basically generating an algorithm to select different bit positions of the transmitted codeword for different integer values obtainable from the algorithm.This scheme is employed in the single bit error correction and single bit error detection.
I am currently faced with a problem of randomly selecting any two different bit positions in such a way that every bit position is selected for different integer value obtainable from the algorithm
I urgently need help on this.Thx
