BirdmanofVT
Greetings. I need to maintain a proper mesh of a drive pinion to an internal gear. The drive is low speed, high torque, and to give you an idea of size, the pinion pitch diameter is ~100mm with ~20 teeth, and the internal gear pitch diameter of ~1600mm with ~325 teeth. The drive system is stationary, meaning it does not travel with the internal gear. I am worried about the tolerance stackup and thus keeping a proper mesh. I think I have to use an antibacklash pinion. Its going to be a challenge to align the pinion even with an antibacklash pinion. I foresee needing to slot my mounting holes and using shims. Let me know if more info is needed to understand my problem. Any advice or a push towards good resources is much appreciated.
Ed
Ed
