Requesting some direction on identifying the Lc dimension for Bearing strength at bolt holes for in plane eccentricity. Using the 13th edition of AISC. Spec J10(a) notes independent of the direction of loading however Lc is defined just below as clear distance in the direction of force. Understood that the coefficient table is available but prefer to hand calculate as well. Thank you
