Johnwoo1991
Materials
Is it a problem in your opinon if i declare on valve general drawing for approval as a stem material ASTM B637 UNS N07718 (which should be similar to ams standards) and then i produce the valvole stem with an alloy 718 certififed to API 6A CRA? Isn't it better one for oil & gas aplications or can it cause issue for material test certificates review?
