Krishnnaa26
Materials
- Sep 1, 2021
- 16
thread338-262770
The remarks column in Table A.13 of ISO 15156-3 permitting to use annealed alloys of Type 4a (Alloy 825) in sour environment without restriction on temperature, ρH2S, chloride concentration and in situ pH. But it is also indicating that no limits on individual parameters are set but some combinations of the values of these parameters might not be acceptable, in production sour production environment.
Table A.14 is specifying the environmental limits for cold-worked alloys, however, the table title includes "annealed" also.
1) Since Table A.13 is not specifying the limits on individual parameters, can the individual parameters specified in Table A.14 for alloys of type 4c, be considered for use of Alloy 825 in Region 3 sour service, without additional testing.
2) Can the limits specified in Table A.14 be considered for weld over lay of respective alloys (Alloy 825) as per A13.2 ( Corrosion-resistant weld overlays) of ISO 15156-3?
3) In the answer provided for "MP INQUIRY #2015-08" in "ANSI/NACE MR0175/ISO 15156-3:2015 Inquiries and Answers",
[.....though there are no environmental limits currently defined below 132°C for UNS N08825, there could be some combinations of parameters including elemental sulfur form (i.e. physically dissolved, solid or liquid) that may not be acceptable.], what is the intent of the word "including"?.
4) As per NACE Paper No. 10262 (Corrosion Resistance of Nickel Alloys and Super Austenitic Stainless Steel Weld Cladding as a function of dilution. By Dirk Aberle, Martin wolf, Friedrich Stenner), considering the dilution effects, can the Alloy 825 WOL be considered in Region 3 sour service(~150°C and 2bar pH2S, 17000ppm chlorides)in view of the lower PREN values in WOL.
