VtwinSpeed
Automotive
- May 17, 2019
- 4
Hello Everyone,
First post on this forum. Didn't see a rules for posting questions so I apologize if its not in the format needed...
I want to make a lighter axle for my Motorcycle and also a friend. Had one machined from Titanium (Grade 5) for the friend. I haven't received feedback if he likes it yet. Now I am wondering If I could use 7075 instead and still get stiffness and strength needed to do the job but also be much lighter than O.E.? O.E. is steel of some kind- a magnet sticks to it. Aluminum (Even 7075 and C4) is still much less expensive than Ti.
What do you guys think? I don't think heat build up will be an issue as it does not spin, the bearings do. It has to resist twisting forces from braking and cornering but that doesn't seem like it should be that bad. You want a stiff material to improve handling which is why I don't think Ti is used commonly (besides $$$).
Thanks for your help.
