Hello good people,
I would like to know if it is possible to convert a dynamo (field wound, not permanent magnet type) to operate as an alternator. The hardware appears to have the required elements, suggesting that I might be able to convert from commutator to slip rings, and excite the field windings from a suitable regulator circuit.
I don't fully understand the workings of an alternator regulator. Can anyone direct me to a website which explains the circuit and its function? The dynamo is fitted to a motorcycle, and will be required to output 12V at around 100W.
Pete.
Pete.
