nolimitmfg
- Oct 9, 2012
- 4
We are currently manufacturing a part out of 6061. The part is very similar to a roller lifter for an automotive engine in shape, and how it must perform. The part is being stressed in compression and also slightly side loaded. There is also lash in the assembly to make up for heat. The part runs in gravety fed oil. It is also hard anodized with a teflon type coating over top of the anodize. We have not had any significant failers, but the customer is asking us to use 7075 instead. Would there be any drawbacks to using the 7075 material such as possibly being more brittle. My concern is the two ears that hold the roller bearing could fatigue and snap off.
