jgattoni
Automotive
- Sep 12, 2013
- 6
Hello, I am having a Mazda 2.3 liter blocks Iron cylinder liners Chromium Nikasil PVD Coated for a specific application where the engine will be subjected to corrosive (sulfuric acid) mixed gaseous fuels. They have responded and said that there is an aluminum lip (part of the aluminum block) at the top of the liner where it is cast into place and they cannot coat it because of 2 dissimilar materials. This makes no sense as they can nikasil coat aluminum OR iron no problem...and as far as there being a ridge after coating where the 2 materials meet, well I cannot imagine the top compression ring comes into contact with the aluminum in the first place...and I verified that the aftermarket pistons going in have the exact same compression height as the OEM pistons that were in there, as well as top ring placement in the piston with respect to the wristpin and top of piston. Do you see any issue here? They want to bore and install full length liners, and I have to say I disagree. Thanks.
