juniorfacadeengr
- Nov 12, 2024
- 4
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I really appreciate your advise. But just wondering does it have any structural concerns?Definitely not recommended.
1. You typically want to avoid embedding aluminum in concrete due to corrosion concerns.
2. The alignment will never be correct.
3. You'll never get the concrete to consolidate properly inside that profile.
4. Contractors will hate you.
5. No adjustment possible after casting.
Yes, those are all structural concerns. I.e., the window will probably fall out and smash someone due to reasons #1 and #3.I really appreciate your advise. But just wondering does it have any structural concerns?
Thank you so much!never place aluminum into concrete
Consolidation issues
Construct ability issues
Mechanical attachment is pretty much the only way to go.
Thank you so much!Construct ability issues
