I am using the Aluminum Association's Aluminum Design Manual to design an aluminum frame with extruded tube shapes and welded connections, and I am a little out of my element working with aluminum instead of steel.
What is the maximum allowable size of a fillet weld based on the thickness of the section that is being welded?
This doesn't appear to be anywhere in the manual, and I can't assume it is that same as the values listed in the AISC manual. Please help! Thanks.
