Dear All,
I have been involved in the verification of a cantilever aluminum rod of 45mm diameter which shall be subjected to a lateral force and subsequent moment. The end of the rod is proposed as welded to the base plate by fillet weld by a client.
I understand that aluminum will be softened by the welding and reduction of the section capacity need to be considered in the design check. The maximum moment will end up exactly at the location of the weld as it is a cantilever. While referring to BS 8118 section 4.4, I came to note that the thickness need to be reduced by the factor of kz. The material proposed is 6063 T6 and the kz is found as 0.45 from table 4.5.
As far I understand, I may need to reduce the thickness by 0.45t for the calculation of section modulus. This may result in substantial reduction in the member. Since it is a round rod rather than tube or other type of extrusion, is it the correct way to calculate the net effective section?
could some one help on this regard.?
