To answer some of the questions
Wall thickness and outside diameters:
Top section 1.5-2.0mm wall thickness, diameter 51.0-51.5mm
Bottom section (standard rig) 2.5-3.0mm wall thickness, diameter 63.5-64.0mm
Bottom section (radial rig) 1.8-2.0mm wall thickness, diameter 63.5-64.0mm
No measurement obtained for the sleeve wall thickness or diameter, but I would estimate it to be 1.5mm, 55mm.
It is my belief that the wall thicknesses are not sufficient when the extrusion dies are new.
There are no wires etc in the sails and no class limitations on the amount of bend you can generate. However the real limitation is how for you can pull the end of the boom down to the deck, which is part of the way the mast is bent.
15 years ago there was a change in the cloth weight of the sails, which increase the stiffness of the sail. However the materials haven't changed since then. However I believe the problem existed before this change and the wind strength we sail in also has not changed.
Even as the Australian measurer, I do not have access to a construction manual. I definitely know that the alloy is either 6061 or 6063 with a T6 ageing process, but no specific knowledge of the YS, UTS or hardness specifications.
There are 3 types of mast, depending on the sail area. The standard rig and radial rig bottom sections are mentioned above. The radial section is shorter and has a sleeve in it to permit a better sail, if a cut down standard section is used, the bottom section is too stiff to permit a fast sail shape to be achieved. The cut of the sail can achieve in achieving a fast sail shape; the reduced length of the mast did not permit enough bend for the sail to achieve this.
The 4.7 mast is smaller again and is designed for the use by young teenagers or very light adults. In order to achieve a fast sail shape, the designers found it necessary to pre-bend the mast, as even a thinner wall thickness was inadequate. Only the 4.7 mast has a pre-bend, the other two are both straight.
Part of the characteristic of a fast sail shape, comes back to the balance and having the tip of the mast back far enough (a bit hard to explain).
"a) Do people try to gain some advantage by cheating a little on this rule?
Or maybe bend & then straighten???
b) There must be some enforcement of this rule, and there must be some tolerance due to original variation as manufactured? ½ degree? What happens to out-of-tolerance masts?"
There is no deliberate cheating to my knowledge on this rule. When people bend their masts, it becomes fairly obvious and other competitors will comment. Most competitors will attempt to straight the masts, particularly top sections that straighten easily. We don’t have a tolerance measurement unfortunately, my general rule is if I can observe that the mast is not straight, I will ask the competitor to straighten it.
The 4.7 bottom section is bent after ageing, using pipe bending equipment, however as the sail is so small; they do not appear to bend accidentally like the other mast sections.
"Alan, can you tell us the radius of curvature of this bend or more simply, the length of the non-straight portion of the mast?"
The top section will bend more than the bottom section and they will be a bit more distortion where the two sections join.
All mast/boom sections are anodized where they are produced, the bend in the 4.7 rig done at the laser builder, so post anodizing. I haven't ever checked the thickness of the layer, but it would be about the standard for commercial anodizing (not hard anodizing).
"To all: (If anodized masts) The anodize could crack and offer lots of crack initiation points if the mast flexed significantly during racing, but how relevant that is for overloading-type failure? My guess is less important than wall thinning."
I've never observed any cracking of the anodized layer caused by ordinary flexing or when the masts have been slightly bent. However when the masts have been badly bent or dented, yes the anodized layer has crazed. I don't think the anodized layer will significantly effect the properties of the mast.
I did my thesis on the corrosion aspects of anodized aluminum copper alloys, the corrosion issues are extremely significant. The way aircraft avoid the problem is by cladding the parts in a layer of pure aluminum.
I apologise if this post doesn't make to much sense, my mind is else where; we are having significant bushfire (wildfire) problems in Australia. Where I am is ok, but I have friend in trouble.
