Amada FO-3015NT Condition explains
Rixxio
Industrial
Oct 29, 2018
1
Hi to All..
i am new in this Laser Cutting business an i am finding really confusing understanding the cutting conditions of the software.. (Amnc03)
There is anyone that can share an explanation regarding how the commands are set up ?
i would really like to understand what : Line 1 doing?
Line 2 doing?
Line 3 ...ecc.
Thank You
Rixxio the 10 lines you see there are nothing more than your cutting conditions (Parameters) the E code in your program will select which of these lines will be active at the time laser start cutting.
I only use 4 of the lines, E003 for inside cuts like holes, E004 for outside cuts, E005 for intricate cuts like letters and E010 for etching [auto]
hi,E9 is for burning folie if you work like that,other rows are used for step piercing,E1 you use when you need to cut for example 4mm hole in 10mm thick steel
