Hi Guys,
Has anyone here actually worked out how to use the Amada jog cut feature on FO machines, the older 160i type not the AMNC type controller.
Spoke with a few others who can't get it to work either.
Here's what we do
Select cutting condition
Select manual mode
turn on jog cut switch
push axis direction
push jog cut interlock button & hold
push jog cut beam on button & hold
Then the beam come on & the shutter opens, then that's all.
I would like to think the head should come down then pierce then start moving the axis, but this does not happen.
Can any one help with this one?
Thank you
Here's what we do
Select manual mode
push axis direction
Thank you
