fdv99
- Jan 22, 2020
- 5
Hello, we have a new to us LC3015 F1NT, it is a 2008 model. When we got it installed and I was getting the software setup, I could load a sheet on the shuttle table while cutting and press "Work Set Ready". I have M707 at the end of our programs, so if the button is pressed the machine will swap the tables. This worked in my testing, but now for some reason I can only press that button on the shuttle table controller if the machine is in manual mode. Is there a jumper or something that allows using some functions of the shuttle table while cutting? I don't understand why it worked before and not now.
It would also be nice to use the bearing scissor lift to load a sheet while cutting, but currently can't do that either. Any ideas?
