Amada network problem
affa289
Industrial
Jul 10, 2017
9
Hi guys I'm trying to setup a LCG3015 on a network so it can accept g codes from sigmanest I can take the code on a USB stick code works fine just need to know how it can be done over Lan network any changes made on the machine to make share folders are reset when the machine is shit down works fine before that any idea on how to keep the settings
We use Predator software Inc. We purchased Sigmanest many years ago and while it was being setup we had 3 people quit in the middle of the setup so we never did get it working.
Hello brother, is your device NT-based?
If yes, then you need to turn off its protection function and set a folder to share,
and the G code can be transmitted to the device via LAN sharing.
