Andy J
- Dec 3, 2016
- 24
Does anyone know of a culvert calculation procedure from the American Concrete Pipe Association on how to correctly calculate flows through a culvert discharging from a pond?
I have a regulator insisting that I use the manning's formula which doesn't take into consideration inlet losses, outlet/inlet controls, low to no velocity of water entering the pipe at the inlet due to ponding??
The culvert will be partially full and I been using a modified orifice equation and heard that it came from the ACPA?
Or if someone can point me in the correct direction to some research papers. Manning is giving me flows 4 times higher than FHWA or the orifice equation which both give me similar values.
