alphamaleomega
I have a 50,000 gpd wastewater stream with parameters as follows:
15 degrees C
100 ppm ammonia,
PH=7.2,
TSS=nil,
BOD5=200,
COD 300 ,
flow rate,
nitrate=0,
nitrite=0.
Need to get rid of the ammonia, and discharge at 20 ppm ammonia or less.
Plan on generating chlorine on-site using a membrane and electrode system, then using the NAOH produced on the cathode to condition one half of the flow to PH to 10.5 + and then air strip the ammonia. May generate chlorine off-site near the ocean and be able to produce it without generating a waste stream and having to haul salt.
The other half of the flow would be treated with chlorine to the breakpoint eliminating all of the ammonia and chloramines.
The flow would be then be re-combined and treated with UV to De-chlorinate, prior to discharge.
Have investigated cost of nitrification/denitrification using biological reactors and favor the chemical method for reliability and quick start-up due to intermittent flows. I realize operation costs are higher.
Any comments appreciated.
15 degrees C
100 ppm ammonia,
PH=7.2,
TSS=nil,
BOD5=200,
COD 300 ,
flow rate,
nitrate=0,
nitrite=0.
