autonub
- Feb 24, 2012
- 13
Hello! I'm having a little difficulty figuring out how to calculate the maximum ampacity of a metal submerged in water with a constant temperature and flow rate. For example, say we have an aluminum cylinder (solid and without insulation) submerged in water flowing at 30 gallons per minute at a temperature of 45 degrees Celsius. The aluminum has an ampacity in air of 700A per square inch. In the event cross sectional areas and lengths are needed, assume its cross sectional area is 0.5 inches squared and its length is 8.75 inches. Alternatively you can make up your own numbers. I only need to see an example. Thanks!
