engreg
- Sep 8, 2022
- 32
The code reads as such....
(b) Anchor or anchor groups shall be designed for the
maximum tension that can be transmitted to the anchor or
group of anchors based on the development of a ductile
yield mechanism in the attachment in tension, flexure,
shear, or bearing, or a combination of those conditions,
considering both material overstrength and strain-hard-ening
effects for the attachment. The anchor design tensile
strength shall be calculated in accordance with 17.10.5.4.
I understand that a) allows for the use of sleeves to provide the ductility.
and d) designs around overstrength * load.
I don't comprehend what the code intends by b. If anyone understands it fully could you explain.... I am designing a 3 story moment-framed building in SDC C and trying to get the base plates smaller, without using sleeves.
Does it mean I can disregard overstrength if I ensure a ductile failure.... the anchor bolts in tension, perhaps.
