An extremely cold question
Artisi
AU
I know there are some great minds here in the pub and there are also some who live in these awful below freezing climates, so lets see who can come up with an answer to this.
A similar thing occurs at boiling point. Many people have gotten injured with microwaved hot beverages that instantly boiled over upon being disturbed after microwaving.
TTFN
faq731-376
7ofakss
The liquid is at or just past its normal phase change point and a shock or disturbance that changes the pressure at certain points in the liquid triggers the change.
Pat
See FAQ731-376 for tips on use of eng-tips by professional engineers &
for site rules
I've have experienced that when you pop the cap off a bottle of beer that's been in the freezer - change of pressure, but in a sealed bottle ????
One difference between water and ice is a lot of BTUs. If the BTUs are already gone you have ice. It's hard to imagine that many BTUs leaving instantly. And water bottles left in the truck in Western Canada freeze solid at temperatures much above -20.
Bill
"Why not the best?"
Jimmy Carter
Shere in the liquid as the water moves does cause short term local changes in pressure due to acceleration and inertia. Same as causes cavitation in a pump.
Once a few ice crystals form, it acts as a nucleating agent, just like scratching the bottom of the beaker with a super saturated salt solution.
Pat
for site rules
I first saw this when I was a teenager. At the time, they didn't sell plastic bottles of water. But I would take a jar of water with me when I traveled. I came out one cold morning to finish unloading my car. I picked up the jar of liquid water and was surprised it was still liquid. I shook it to verify it was still liquid and it froze solid in front of my eyes.
Sub-cooling is the equivalent of super-heating in a micro-wave as mentioned above. The water has to be very pure and the container has to be very clean. If there is even a speck of dust, it will nucleate an ice crystal and freeze.
They did a segment on this on Myth-Busters. They used beer rather than water.
Johnny Pellin
Corona (beer) does this for me every Tuesday and Thursday when I finish my workout. The key is to get it to just freeze a little bit, which requires putting the beers in the freezer during a particular segment of the workout.
a couple of good articles on the subject of supercooling:
This article, which requires payment, mentions another common supercooling phenomenon, which is more robust than supercooled water: supercooled sodium acetate, used for "instant" heating during the winter:
What's interesting is that for sodium acetate, the freezing initiation requires a fairly energetic disturbance, i.e., the metallic clicker. Moreover, the heat of fusion isn't really removed until the trigger event, which is where the heating from the packet comes from.
What that says, then, is that supercooled water is technically not yet frozen, because the heat of fusion is still retained within the bulk of the material, and it's likely that the "instant" freezing is actually accompanied by a rapid rise in temperature. Might be interesting if someone actually does the temperature measurement during these events.
TTFN
faq731-376
7ofakss
That was freshman (high school) physical science. Yes there is a rapid temperature rise. Supercooled down to about -4C, when disturbed it froze solid and jumped to 0C.
Also happens on aircraft wings, but changes instantly from supercooled water vapor directly to ice. No liquid phase involved at all.
From "BigInch's Extremely simple theory of everything."
Greg, Did it hurt when you fell to Earth?
Nicely struck, Greg. 'Course I lobbed it in right over the plate.
