AleksaBgd94
- May 30, 2018
- 52
Hi everyone,
Abaqus exited with this error:
8 nodes on an embedded element do not lie in any host element. Check coordinates, exterior tolerance and absolute exterior tolerance parameters, and the host element definition. The nodes have been identified in node set ErrNodeEmbeddedNode.
2378 elements have missing property definitions. The elements have been identified in element set ErrElemMissingSection.
***Error: An-out-of-memory error occured. If you have access to a machine with more physical memory, you can try running the application there.
I really can't realise where my mistake is because it was pretty simple to define embedded region and host element.
If you have any idea or need more information please write.
Thanks in advance.
Thanks in advance.
