Negative eigen values error
Ali asger
Student
Nov 5, 2024
9
Hello there , I am modelling a composite slab as SIF 1 i have provide surface to surface contact between steel and concrete and boundary conditions i have applied using a rigid body tie constrain to a reference points and loading i have used coupling to a reference point and applied a point displacement of 15mm , my problem is my model is taking too much time , further it is getting aborted and most common warning i am getting is of negative eigen values and when i am comparing my model to an actual experimental data the initial stiffness is not matching correctly please help me regarding above mentioned issues.
Thankyou
Can you share the file (.inp or better .cae) ? It's hard to say without seeing the details.
Please check model-1 and please help me fixing its initial stiffness , i am validating my model with a research paper , i am attaching its graph please check it
Thankyou
  • New Model.zip
