FEAMonkey
Aerospace
- Nov 17, 2019
- 15
Hi Everyone,
I have modeled a plate with a center hole in Abaqus as a 3D model and used shell elements. In order to stop the top edge from bending during the load, a Pin(nodes) constraint has been applied on the top edge. I have worked in mm when I modeled this component. My dimensions have to be in mm as I am using the results for further analysis in MATLAB. You can see my setup here.
This is my Von-Mises result: (max 1.451*10^4)
I would like to validate my result using hand calculations. I have found the appropriate (I believe) equations on this website:
I have created an excel spreadsheet to calculate the maximum stress at the horizontal points of the hole:
As you can see, my results seem to be off by a factor of 4. It must be some sort of conversion error in Abaqus or in my equations.
I don't know how Abaqus calculates its results. Therefore, I don't know how to change my values in my spreadsheet to get the expected results.
Can someone take a look at my spreadsheet and explain to me how I can fix this problem?
Thank you for your help.
