"inertia relief" is the opposing inertial force that is created when a load is applied, if "relief" is confusing, just call it "inertial force" or "inertial reaction". On a wign the aerodynamic loads are up and the inertial loads are down (hence the inertial loads are relieving the aerodynamic ones).
All stress analysis FEMs need to be restrained in 6 dof (to take out rigid body motion, to "nail" the model in space). these constraints should not generate reactions. if they do it means your loads are not balanced, or your constraints are over constraining the model. in a pressure vessel you should be able to constrain 3 nodes (xyz, xy, x) to take out rigid body motion. if you are new the FEA, read up on this.
If you tell the FEA that this is an axisymmetric model, then it applies the relevant constraints, and so maybe you need fewer rigid body constraints. read up on this. if you have solid elements in your model, you have only three dof at each node ("fully constrain" is usually used to describe constraining all 6 dof).
