Analytical solution for this geotechnical problem
awa5114
135
This is a geotechnical problem that I am seeking an analytical solution to.
A soil layer of depth H and width L is loaded in plane-strain by a periodic load of F=sin t, where F is in units of Force/Length^2. The soil layer is perfectly linear elastic, fixed at the bottom in horizontal and vertical directions. At either side it is fixed only in the horizontal direction.
I would like a physical/mathematical model that can come up with resulting stresses, strains, displacements, accelerations and velocities at any point (x0,y0)(x0,y0) as a function of time. All material parameters are readily available, including Poisson's Ratio and Shear Modulus.
PLease see attachment for a graphic of the problem...
 http://files.engineering.com/getfile.aspx?folder=71aa0ca4-7533-4bb5-b364-7d55b9c87c4e&file=Problem.jpg
Looks a lot like a homework problem I had in grad school
The prof had a rough party last nite last nite lasting until daylight.
