Analyzing and exporting results from a large number of load steps
Will Klausler
I am working on an analysis which requires data from >100 load steps. I understand how to do everything in a single step with the GUI/commands, but not iteratively.
I am trying to do the following:
-Define the load steps
-Analyze with each load step
-Export certain results from each load step (into Excel or Matlab)
Conceptually, this is a straightforward operation, but I haven't yet figured out how to do it in the MAPDL through a for/do loop
Any help would be appreciated
Thanks in advance
Will
Try something like this:
/solu
*do,ls,1,100
time,ls
f,,,,,
d,,,,,
etc.
solve
*enddo
/post1
*do,ls,1,100
set,ls
*dim,data,,,,,,
*vfill,data(1,1),ramp,1,1
*vget,data(1,2),node,1,s,eqv
*vget,data(1,3),node,1,u,x
etc.
*cfopen,stress%ls%,dat
*vwrite,data(1,1),data(1,2)
fortran format statement
*cfclose
*cfopen,defl%ls%,dat
*vwrite,data(1,1),data(1,3)
*cfclose
*enddo
The *cfopens will create files named stress1.dat,stress2.dat, defl1.dat, etc. You can just as easily put them in one file if you prefer.
Rick Fischer
Principal Engineer
Argonne National Laboratory
Thank you!
Both replies have helped a bunch.
However, I'm still hung up on applying loads. I want to apply a pressure function on a set of nodes, and haven't gotten it to work through commands, only the gui. My approach is sf, [array of nodes], pres, [pressure function] but this fails at the array. The nodes are valid/have valid geometry. The documentation suggests a P51x, but I haven't figured out what that means.
Thanks again,
Will
If you've gotten it in GUI, the APDL commands should be reflected in the LOG file you could use as reference.
Kind regards,
Jason
