I’ve been asked to furnish a proposal for analyzing capacity of an existing mezzanine supported by a simple steel structure (HSS truss joists/girders, HSS columns, corrugated decking, etc) in an industrial unit. I primarily repair existing structures, but I don’t much analyze them for others / provide them with design loads of such; so, I had a few questions / concerns that I wanted to know how others have dealt with:
1. In order to determine steel properties I will take coupons. My question is how many? I figured at least one in every type of structural element though am thinking I may want more to make sure the variance per element is within a tolerable range.
2. I have yet to visit the site but from pictures it looks like the structure is well built, though the connections appear a bit suspect. For example, the supporting HSS columns (appear to be 4x4 of unknown thickness with a 10x10 BP) have 4 threaded rod anchors that appear to be 1/4" or LESS. Now, the structure is made up of interconnecting simply supported elements so technically the capacity shouldn't be governed by these anchors...but for comparison I specify 1/2" anchor rods for garden variety steel guard rails on accessibility ramps. Compared to the column it looks like the anchors came from a kid's playset. Add to that the anchors will be of unknown embedment with unknown embedding methods. I'm concerned of you know...things (forklift hits the structure while fully loaded, someone impacts the structure by dropping a pallet rapidly that causes deflection leading to P-Delta that destroys these flimsy anchors, etc). How do I evaluate the capacity of the structure in light of this?
3. How do I reconcile the theoretical capacity of the structure vs the installed structure, which has connections that I couldn't verify / welds I didn't inspect prior to paint, etc? I imagine if I provide a theoretical capacity with a caveat that it is based on a certain weld condition (that cannot be checked at present or at least not for a reasonable sum of money) that I would be liable in the event that something happens upon loading to the theoretical limit. Do I just calculate a theoretical capacity and add a comfortable margin of safety to account for such things?
4. Other things to consider from those that provide reports on such things?
