Aakalim103
We have a situation where anchor bolt grout pockets for a industrial silo are casted at the wrong location such that the whole bolt assembly is off set by a few degrees. The pockets were casted against a spiral steel pipe and were meant to be filled with epoxy non shrink grout after installation of bolts. The simple solution is to drill a new hole besides it, however, the new hole will intersect with the casted pocket at the edge, as shown in the attached figure. The contractor has indicated that they want to just drill the new holes and then grout the entire new cavity with the epoxy grout. However, my suggestion to the contractor will be to first fill the casted hole and then drill the new hole. Do you think this is necessary?
