BSVBD
- Jul 23, 2015
- 463
(Considering ONLY 3/4" Anchor-Bolts - for example)
AISC 13th, Table 14-2 provides "Recommended MAXIMUM Sizes for Anchor-Rod Holes in Base Plates.
Considering the 3/4" anchor bolt, this table allows the hole to be 9/16" larger than the bolt.
AISC 9th, 4-130 says "Hole sizes for anchor bolts are normally made oversize to facilitate erection as follows: Bolts 3/4 to 1 in. - 5/16 in. oversize..."
When would one specify the MAXIMUM Oversize of 9/16" versus the "normal" Oversize of 5/16"?
Over the years I've seen various specifications. I'm trying to assist a General Contractor with establishing a reasonable standard.
Please include and cautions I may not be considering.
Thank you!
Thank you!
