i have an angle iron spec'd out to bridge between two roof joists to mount a crane to (threaded rod through bolted into angle iron flange) - based off L/360 & L/240 deflection requirements i have landed around a L6x4x5/8" angle spanning the joists (5'-8" OC). the hanger load is centered and 1852 lbs, can meeting deflection control this spec'd angle or do i need to check flexural of the flange / how do i do that
