kaspor
- Aug 12, 2021
- 33
Hello
I have to install some large steel angle lintels above some 5-6m wide commercial style windows. They are going to be installed in a brick veneer wall.
Due to width the lintels have to be welded to PFC beams (which are located in the timber wall cavity supported by SHS posts either side). The lintels will then sit above the window supporting brick work.
I’m not sure if you need to allow any clearance between angle lintel and the window itself. I see the engineering calcs are stating that the steal beams to which the lintels are welded to have up to 16mm deflection.
Typically the steel beams are 20mm above window height. But I don’t want to leave too much gap between the window and lintel as I’m not sure how to seal the gap later on.
Should a 20mm be allowed to deal with the beam deflection?
