jsu0512
- Aug 1, 2017
- 32
Hello Everyone,
I need some help with analyzing the strength of the angle leg when the uniformly distributed load is applied in perpendicular to the angle leg. (See the attachment)
As shown in the attached drawing, the angle size is 5"x5"x1/4" thickness with 49 inch length and applied with the uniformly distributed load at 105mm offset from the concrete curb. To check the strength of the angle leg, the thickness (1/4") and length (49") of the angle leg was used to calculate the section modulus, before calculating the moment resistance of angle leg . (Mr=0.9*S*Fy)
And for the Factored Moment, I calculated the point load by multiplying the uniformly distributed load(kN/m) by the angle length (1244mm), and then calculated the factored moment accordingly. (Mf=1.25*w*b*r)
Please let me know if I am on the right track.
