Hi all
I'm having this confusion about a certain system where I'm not sure how it would act in either of two ways.
Basically system is a weight of one Kilogram falling down and interacting with a body of neglegible weight. the two bodies connect together and start travelling down at the same speed. the weight connects to the weightless body through a circle touching an angled surface of 45 degrees which in turn is connected to the weightless body.
I attached a drawing where the weight is labeled as A while the body of negligable weight is labeled as B.
now given that they are travelling together at same speed I can't decide what is downward force applied by Body A on Body B. is it equal to full weight of A since they are falling together?
or is it half of the weight since they are interacting at a 45 degrees angle?
I highly appreciate your response as I'm scratching my head by now.
Just for clarification: the two lines around the bodies in the drawing are meant to represent rails to guide motion.
