Angular bearing
prym
16
What is the methodology to analyze angular bearing?
1. What co-ordinance system should I use?
2. How to constrain inner, outer and the balls? (particularly the balls?)
3. What contact should I use for balls and rings?
prym,
How did you define your contacts? If you defined them surface-to-surface, then i wouldn't expect that message. If you defined your contacts as part-to-part, it's possible that contact definitions were created for other surfaces (e.g., the flat end faces).
Seems like you're starting to get on the right track with models of increasing complexity. Good luck
Peter
