harshitpuri
Automotive
i'm trying to simulate a rollover of a rigid body with point/structural mass inertia in order to analyze the barrier on which it will be falling for impact analysis. For this i've created a 3d deformable plate acting as ground and thereby converting it into rigid body via rigid body constraint through a reference point coupling.the barriers are in tie contact with ground. i've given angular velocity to one edge of the plate and the whole body is in the gravity load, however so while doing so the plate is not rotating although its boundary conditions are not constrained of the rotation axis about which it is rotating say x. and other translational dof are also free which should allow other end to rotate. the angular velocity is not propagating through plate. i've attached a picture showing the angular velocity is not transmitting through the plate.
