gwr2
Military
- Dec 18, 2013
- 4
We are manufacturing a curved face shield out of Polycarbonate. It is die cut from a flat sheet of Makrolon GP. The frame that it gets mounted in has a simple bend around 1 axis, forming a cylindrical shape. Easy enough shape to make. Is it possible to build a fixture which holds the flat blank in this simple curve and anneal the plastic to permanently set the curve? It appears to work, processing at 130C for 1.5 hours but I am concerned that this is an unconventional technique and problems will arise months later that we are missing today.
We have tried drape forming, but the process seems less reliable. The material cools so quickly, slight variations in handling time coming out of the oven cause varying results. We have limited resources for heating and forming.
Leaving the lens in the flat state and installing it stressed into the frame has shown much more sensitivity to environmental stress cracking. We need a way to effectively form.
Thank you for your help. I have enjoyed reading other posts on the subject of forming and ESC, you guys have the great knowledge base going.
Best regards,
Best regards,
