JONI101
Industrial
- May 21, 2015
- 8
Hello
I am inspecting water storage tank which designed according awwa d100 and api 650 standards, 13.5 m diameter, sa 516 gr 70
In the original design there is an annular ring which ofcourse welded by butt weld and also bottom plates which are also welded by butt weld, the connection between them is lap welded.
The contractor wants to connect them by butt weld which means all the floor will be butt welded.
Is it ok according to api 650 or awwa?
Many thanks
Many thanks
