Anodize over Flame spray
Datech
New member
Sep 3, 2003
12
Have a part that required flame spray Mil-Std-869,Then hard anodize Mil-a-8625 type III. First attempt flame spray pitted and peeled after anodize. Flame sprayer says you cant anodize over flame spray.Does anyone know about these processes?
Boeing & Douglas call for either a Sealer Coat or Surface Treat with Alodizing (Alodine or equiv.).
I have never seen the requirement for Hard Anodize on Aluminum Flame Spray. Doesn't mean there isn't one, but it doesn't make sense. Aluminum Flame Spray is a very soft Aluminum Base Material (1100). If a harder material is required (for a Hard Anodized Surface), a harder Plasma Spray Material should be called for.
Aluminum Flame Spray is used for electrical protection or as an Antenna, not a wear surface.
Repair says flame spray SF aluminum to above mil std. grind to dimension .Hard anodize to mil std . Its a cessna part . Military application. Repair info is a T.O..
Well, you have me on this one.
I wouldn't "grind" Aluminum either!
Don't know what SF Aluminum is, but will check it out.
Just curious...what is being repaired with Aluminum Flame Spray?
Which flame spray is called for in the repair? I mean, which powder or wire to use?
Anyway, whether the plame spray coating is for dimensional restoration or a wear resistant coating like carbides, anodizing over a flame sprayed coating seems VERY strange to me, as this process needs really 'contact' with the base material.
Only says Flame spray SF Aluminum.
