Harper57
- Jun 17, 2019
- 14
I am looking for a way to control the speed at which a spring-loaded device returns to the original position.
How this is supposed to work is that there are panels with graphics. A question is on the left, a photo in the middle, and an open space on the right. The photo is on a fixed panel above the one below, which includes the question graphic. So the lower panel is twice as long (or wide). The bottom panel slides to the right, and the hidden answer (printed on the panel below) is revealed as the panel moves.
Once the panel is released, it should return to the left, to the reset position. Whenever I've tried this sort of thing using a spring, it snaps back too forcefully and it could cause injury. Could I use a rack and pinion to slow down the return movement?
I'm thinking that a spring is hidden underneath, which is attached to a fixed surface on the left, and to an axle of some sort on the sliding panel. This axle has the pinion, which meshes with a fixed rack below. Would this regulate the speed of the motion, or would the spring just pull the panel back at whatever speed the tension produces?
Is there a better way? Using a small door closer type gas spring?
Thanks again as always!
