ANSI Nut Standards
OTHGWayne
42
To anyone's knowledge, is there an ANSI standard or any other American standard that governs the family of hex nuts known as acorn, cap or dome nuts?
My primary area of interest is in tapped-thru acorn nuts.
Any idea what ANSI (or other) standard would cover these? I have searched the Internet and found nothing. I have gone through ANSI B1.2.2 and found nothing.
Any help would be appreciated.
Sorry, the ANSI standard I've looked through is B18.2.2 not B1.2.2 as in the original post.
See the Glossary of Terms for Mechanical Fasteners ASME B18.12-2001. Following is a list of related screw and bolt standards:
Clearance Holes for Bolt Screws and Studs . . . . . B18.2.8-1999
Fasteners for Use in Structural Applications . . . . B18.2.6-1996
Hexagon Socket Button Head Cap Screws (Metric Series) . . . B18.3.4M-1986(R1993)
Hexagon Socket Flat Countersunk Head Cap Screws (Metric Series) . . B18.3.5M-1986(R1993)
Hexagon Socket Head Shoulder Screws (Metric Series) . . B18.3.3M-1986(R1993)
Machine Screws and Machine Screw Nuts . . . B18.6.3-2003
Metric 12-Spline Flange Screws . . . B18.2.7.1M-2002
Metric Formed Hex Screws . . . B18.2.3.2M-1979(R1995)
Metric Heavy Hex Bolts . . . B18.2.3.6M-1979(R1995)
Metric Heavy Hex Flange Screws . . . . . B18.2.3.9M-2001
Metric Heavy Hex Nuts . . . B18.2.4.6M-1979(R1998)
Metric Heavy Hex Screws . . . . B18.2.3.3M-1979(R1995)
Metric Heavy Hex Structural Bolts . . . B18.2.3.7M-1979(R1995)
Metric Hex Bolts . . . B18.2.3.5M-1979(R1995)
Metric Hex Cap Screws . . . . B18.2.3.1M-1999
Metric Hex Flange Nuts . . . B18.2.4.4M-1982(R1999)
Metric Hex Flange Screws . . . . B18.2.3.4M-2001(R1995)
Metric Hex Jam Nuts . . . B18.2.4.5M-1979(R1998)
Metric Hex Lag Screws . . . B18.2.3.8M-1981(R1999)
Metric Hex Nuts, Style 1 . . . B18.2.4.1M-2002
Metric Hex Nuts, Style 2 . . . . . B18.2.4.2M-1979(R1995)
Metric Machine Screws . . . . B18.6.7M-1999
Metric Round Head Short Square Neck Bolts . . . B18.5.2.1M-1996
Metric Round Head Square Neck Bolts . . . . B18.5.2.2M-1982(R1993)
Metric Series Hexagon Keys and Bits . . . . B18.3.2M-1979(R1998)
Metric Series Socket Set Screws . . . . . B18.3.6M-1986(R1993)
Metric Slotted Hex Nuts . . . . . B18.2.4.3M-1979(R1995)
Metric Thread-Forming and Thread-Cutting Tapping Screws . . . B18.6.5M-2000
Miniature Screws . . . . B18.11-1961(R1992)
Plow Bolts (Inch Series) . . . B18.9-1996
Round Head Bolts (Inch Series) . . . . B18.5-1990(R1998)
Round Head Square Neck Bolts With Large Head (Metric Series) . . . B18.5.2.3M-1990(R1998)
Screw and Washer Assemblies—Sems (Inch Series) . . . .B18.13-1996
Slotted Head Cap Screws, Square Head Set Screws, and Slotted Headless Set Screws . . . . B18.6.2-1998
Socket Cap, Shoulder, and Set Screws, Hex and Spline Keys (Inch Series) . . B18.3-2003
Socket Head Cap Screws (Metric Series) . . . . B18.3.1M-1986(R1993)
Square and Hex Bolts and Screws (Inch Series) . . . . B18.2.1-1996
Square and Hex Nuts (Inch Series) . . . . . B18.2.2-1987(R1999)
Square Head Bolts (Metric Series) . . . B18.2.3.10M-1996
Thread Forming and Thread Cutting Tapping Screws and Metallic Drive Screws (Inch Series) . B18.6.4-1998
Track Bolts and Nuts . . . B18.10-1982(R1992)
Wood Screws (Inch Series) . . . B18.6.1-1981(R1997)
Thanks for the reply Seagull, but exactly where is the acorn nut information that I identified as being my main focus?
I don't find anything about acorn nuts in ASME. I see references to acorn nuts in Chinese National Institute of standards and several flareless acorn references in SAE including AS 1581B, MA 2064A, MA 2076A, AS 4444, AS 4696, AS 7403A, J 483 and AIA/NAS 1760.
