I am currently helping my company revise our ANSI pipe specs.
What we are finding is that for normal-temp specs (both sweet and sour service), some companies have chosen to specify low-temp materials for larger diameters. For instance, B-spec will switch to low temp for 24 NPS, and C-spec will switch to low-temp materials for 10 NPS and above.
What's interesting, is that some companies specify low-temp for pipe only; some for pipe and fittings; some pipe, fittings, and flanges; and some specify all of pipe, fittings, flanges, and valves to be low-temp above a certain diameter.
Does anyone understand the reasoning behind specifying low-temp materials for larger diameters in normal-temp specs?
Thanks, JA Boomer
Thanks, JA Boomer
