Ansys Picker Dialog...not showing up
cnuk
75
I don't know if it is just me, but I seem to have a lot of problems with the Picker Dialog not showing up after using Ansys for a short period of time. For example, I was trying a simple model last night and after solving I went back to apply another load. After I picked "load on area", etc, the picker dialog would not show up. Someone (drej) previously suggested using the "bring to front" button but that does not work either. It is not just the load command. At this point other commands that require the picker dialog also show the same problem.
Any ideas?
Thank You
What version (including patch number, if applicable) are you running? On what OS?
This behaviour was meant to have been fixed in version 8.1, but wasn't. The workaround is to do the following:
- Zoom out of your model (fit to screen)
- Box zoom into a portion of the model
- Zoom back out again
Hey presto, the picker box will return. Not sure if this has been fixed in v9.0 as I am still using good ol' v8.1 - hope so.
By the way, you mention that I suggested using the raise/hidden button - well this is an entirely different problem, this is a bug, the other is not.
Cheers,
-- drej --
I believe that CTRL-SHIFT-DELETE also works. You'll even get a little "Sorry" message in your output window.
