Ansys Post Processing
jmpark
1
I used Ansys Workbench 14.0 Magnetostatic Analysis and got solution done. However, I would like to plot Magnetic Flux Density along a path. This path is not along an edge of a solid body but a straight path in air.
Is there a way to create a path and export data to plot in MS Excel?
I know it can be done in Ansys Classic using commands like path, ppath, pdef, and plpath. Is there a way to import Ansys Workbench file (with solution) to Ansys Classic and do a post-processing there? I've read a few post that Ansys Workbench is designed for the front-end of the Ansys Classic (APDL), and if that is the case, I should be able to do post-processing in Ansys Classic, right? A step-by-step instruction would be appreciated.
Thanks.
