ansys two way slab analysis
player-1123
IN
Solver pivot warnings or errors have been encountered during the solution. This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues. Check results carefully.
this is the error which i am getting everytime i treid to solve. can someone please help i have to submit it as my college project it is urgent and important too. i am adding my ANSYS file also please explain me or make the necessary changes.
 https://files.engineering.com/getfile.aspx?folder=e37d1d72-1378-425d-bf72-1c7a5f8256a5&file=sa.wbpj
when i do analysis on concrete after supressing all the other body its shows result but when i add reinforcement ot give above mentioned error. someone please help me out
It's possible that you haven't properly established connections between components...
Your .wbpj seems to be devoid of the necessary files and so i cannot open it.
?? So you have already fixed your initial error and gotten results out of your model?
First of all, being a student project, this should be in the student forum. If you don't understand how to interpret the results you've already found - that is half of the reason you are in school and seems like a pertinent question for your prof.
Next, you can't just upload your .wbpj file; I'm not sure what sort of information it contains, but it's likely just pointers with no underlying data. You'd have to archive your project, probably after deleting all of the mesh/solutions/results to get it to a reasonable size (77kb is at the low end of unreasonable sizes).
"Your .wbpj seems to be devoid of the necessary files and so i cannot open it"
gl
Sir today only I have got the results from ansys model and I am currently working on its validation by solving it myself.
Sir there is one more thing I need to ask how can I change the material of just 2-4 beam in the grid of reinforcement. I tried by selecting the beam and changing its material but its not working.
My project mentor don't know how to work on ansys. he wanted me to make some presentations and complete my project.
Really appreciate your help sir
 https://files.engineering.com/getfile.aspx?folder=f43f11c7-140e-4bf6-af90-dabc6f96e883&file=explicit_files.rar
