ANSYS workbench parametric expression
Hasan8703
1
Hi all, I am trying to write an expression in ANSYS Workbench Parameters Correlation outline. I have an input parameter defined as P1. Now, I need to define another input parameter P2 which is a function of P1,the expression of which is P2=sqrt(100^2-P1^2).But Ansys is not accepting the expression and giving error message such as 'sqrt name not defined'. However, if I set P2=P1, then it gets accepted. I would appreciate if anyone can help me. Thanks in advance.
