chris564001
Marine/Ocean
- May 13, 2016
- 2
i'm hoping to get a bit of assistance with stopping a nut from coming un-done if possible.
I have an application using a load cell which is being inserted into metal rod, and then pulled under tension. The load cell is inserted into a hole drilled in the rod and screwed in at the bottom end (loosely). The load cell has an external thread on the other end, which then has a nut placed on it and screwed down 'tight'.
my problem is that I cannot apply large amounts of torque to the load cell as it starts changing the output. But I also need it tight enough so it cannot come undone.
At the moment I have a nyloc nut on the thread (m20x1.5), I have tried using Nordlock washers but couldn't tighten the load cell up enough to get them to work.
the problem is I cannot measure how tight I am doing them up at the moment as I do not have a method of doing so.
But does anybody know of a good method of stopping a nut from coming undone when it isn't torqued up high to start with?
I cannot post drawings/images as its commercially sensitive.
thanks,
thanks,
