YuleMsee
- Apr 8, 2018
- 68
Did a recon visit to a building I've been asked to give an opinion on for the cause of cracking and recommend remedial measures.
Photos and a preliminary structural layout are attached. The building has ground + 3 suspended levels then a pitched roof, gravity load path is through load bearing natural stone masonry walls with some 250x250mm columns as shown. Foundations for the walls are strip foundations. Slabs are 150mm thick with 450x200mm beams.
Along gridline C there is a level change on the floor slab as indicated on the layout with a staircase and on the photos you can see different floor slab beam levels.
The crack also runs along this gridline, its visible on the exterior and interior wall surfaces, runs also on the floor slabs.
An attached sketch also shows how the land around this building is like, there is a slope on two sides of the property captured with the orange pen. one photo captures the slope as well.
I intend to bring on board a geo-tech engineer as I think the slope and the less than one year old neighboring building may have an effect. I also intend to do some reinforcement scans on the floor and beams at the crack location just to see how the step was implemented. Finally open an area to look at the size strip footings.
In your enlightened opinion, what else should I investigate
Though I have to admit the nature of the crack is giving me pause, wondering whether I'd like to be involved in this!
