APDL Script/Commands Editor
Vitkacy1989
54
So far I am using Notepad ++ to create my scripts input files. Is there any editor that would be able to show syntax of APDL commands when writing them? And perhaps would be able to auto-finish/propose commands that you start to write?
Example: user writes in editor EMODIF and editor shows him assistance information such as "EMODIF, IEL, STLOC" so user knows what data is required next.
Thanks!
I think there is no such a thing or is not up to date. If you use Notepad++ you can start with in
Code:
C:\Program Files\Notepad++\autoCompletion
or
Code:
C:\Program Files (x86)\Notepad++\autoCompletion
folder and create your own file. I attached an example file with some commands as a hint.
Best regards
JK
 https://files.engineering.com/getfile.aspx?folder=e19b4d81-372b-4e55-af93-72596f0051ef&file=apdl.xml
Isn't this a thing in the newest version 2019 R3 when writing to command object?
Yes, it is. But I think the original post is meant outside ANSYS environment. I did some "copy/paste/replace" trick and I got basic commands without description. At this point it is necessary to open specific command and add the details or do some grab script to extract the details and do again "copy/paste/replace" tricks. See attach.
Best regards
JK
 https://files.engineering.com/getfile.aspx?folder=e36b0161-87af-4e84-9951-c613227f6383&file=apdl.xml
Dear Jason,
yes, it exists, but as the command only hint, not as the syntax of the command itself. And the original post asked for the whole syntax of the command.
Best regards
JK
